M
Mathias
Dear ng,
I need to drive a high-pressure mercury short arc lamp (HBO100) with a
lowcost power supply as a microscope light source (I've got a proper
secure lamp house, so don't worry about exploding lamps). The lamp needs
a current of exactly 5A at 20V, and so far I've used two computer ATX
power supplies in series (24V, max 30A), and a ~0.8R resistor (with
additional manual adjustment for the lamp's warm-up phase). The lamp
needs a curent pulse of ~4kV to ignite, which I use a piezo element for.
I hope you can read my ASCII-art, but so far it's really simple
P+24V:--0.8R-+----+
S L:5A Ig:4kV
U-:----------+----+
PSU: 2xATX, L: HBO100 lamp, Ig: Piezo ignition.
Now this works somehow (pressing the piezo button ~40 times is tiring,
but ok...) but only for a few starts.
I guess that the high voltage pulses gradually destroy the capacitors in
the ATX PSUs (do they?).
So my question is: do you have suggestions how to seperate the high
voltage pulse from the PSUs? If I use a 10kV rated capacitor at the PSUs
output, it prevents the lamp from igniting. If I applied the ignition
pulse with reverse polarity, I might use diodes to prevent the pulse
from reaching the PSU, but are there 5A rated diodes which are quick
enough for the ~1ms (?) pulse? Would it help?
Alternatively, I could of course use a commercial PSU but that is beyond
150..200$ even at ebay, and I need something an order of magnitude
cheaper
Thanks a lot for any suggestions!
Mathias
PS: does anybody know a way to generate 4kV pulses easily without manual
button-pressing?
P+24V:--0.8R-+----+
S L:5A Ig:4kV
U-:----------+----+
cheaper
Mathias
button-pressing?
