Problem with writing eeprom memory
Discussion in 'General Electronics Discussion' started by Novacicm, Aug 12, 2017.
  1. Novacicm
    Novacicm
    Aug 12, 2017
    3
    I am trying to write atmel at28c256 on breadboard so I tied all address lines to ground, and all I/O lines also tied to ground. I untie I/O lines for reading, tie 'WE to high, 'CE to low, and 'OE to low for reading. I am reading all ones at I/O ports, no matter what address. So, when I try to write this eeprom I put 'OE high and with 'WE line I touch to ground so that should write stuff to memory but it does not, all I/O ports were connected. I also made small RC circuit with button on WE but that also does not work. Any toughts?
    #1
    1. Advertisements
  2. Novacicm
    kellys_eye
    Jun 25, 2010
    3,429
    909
    West Coast, Scotland
    Have you read the data sheet for the device? It gives all the details of the parameters needed to read/write from the device.
    http://ww1.microchip.com/downloads/en/DeviceDoc/doc0006.pdf
    When you've connected and tried to program the device according to the data sheet and still ahve a problem then get back to us.
    kellys_eye, Aug 12, 2017
    #2
    Novacicm likes this.
    1. Advertisements
  3. Novacicm
    Novacicm
    Aug 12, 2017
    3
    Yep, I already saw datasheet and tried to write a memory as it says but stil same problem.
    #3
  4. Novacicm
    kellys_eye
    Jun 25, 2010
    3,429
    909
    You will - a standard 'unprogrammed' EPROM is usually set to FF (all locations).
    #4
  5. Novacicm
    Novacicm
    Aug 12, 2017
    3
    Yeah I know that but also when I try to write memory to some pattern of 8bits I am always getting FF all ones in memory.
    #5
  6. Novacicm
    kellys_eye
    Jun 25, 2010
    3,429
    909
    If you have tied all address and data lines to zero the programming function (assuming you get the proper 'low' pulse applied) will write whatever you have set on the data lines to the address you have on the data lines.
    Assuming all lines are zero then the programming pules should write 00 to address 0000.
    Have you got pull-up resistors on address/data lines?
    Have you got proper supply line decoupling in place?
    Have you got a de-bounced program signal?
    #6
    1. Advertisements
