Problem with Synchronous Motor
Discussion in 'General Electronics Discussion' started by Hammerhorror, Aug 9, 2018.
  1. Hammerhorror
    Hammerhorror
    Apr 19, 2016
    13
    Hi
    I have a globe light. One that has LEDs inside, and a Synchronous Motor. It was dropped on the floor, and the shaft from the Synchronous Motor was damaged. I've bought a replacement Synchronous Motor, connected it to the circuit and it doesn’t work. I have even tried connecting it straight to the 6v AC. Still nothing. You can feel an initial restistence in the motor every time it’s connected to the power, but still it doesn’t rotate. I have four of these motors, and get the same result from all four. I can only guess that I’m doing something wrong.
    Any advice please would be appreciated.
    #1
    1. Advertisements
  2. Hammerhorror
    Minder
    Apr 24, 2015
    2,599
    536
    Canadian Midwest
    More info on the motor would help.
    Part No.
    Pic etc.
    M.
    Minder, Aug 9, 2018
    #2
    1. Advertisements
  3. Hammerhorror
    Hammerhorror
    Apr 19, 2016
    13
    It’s a
    TYC-30
    AC 6V
    50/60Hz ROHS
    5 rimin 1-1.5
    CW/CCW
    The same specs as the original motor, only it has a different model number. Couldn’t find the original anywhere. The ones I have came from China
    #3
  4. Hammerhorror
    Hammerhorror
    Apr 19, 2016
    13
    #4
  5. Hammerhorror
    Minder
    Apr 24, 2015
    2,599
    536
    Canadian Midwest
    Is that is only 5rpm, were you expecting it to rotate a high speed perhaps?
    M.
    Minder, Aug 9, 2018
    #5
  6. Hammerhorror
    Hammerhorror
    Apr 19, 2016
    13
    No just slow. So it rotates the lens, making the light from the LEDs rotate around the globe
    #6
  7. Hammerhorror
    Minder
    Apr 24, 2015
    2,599
    536
    Canadian Midwest
    So it is not even turning at 5rpm?
    It looks like a simple timer motor with just 2 connections,
    Sure you have the right voltage?
    They usually have a small internal 'kicker' to start it off in one particular direction.
    M.
    Minder, Aug 9, 2018
    #7
  8. Hammerhorror
    Hammerhorror
    Apr 19, 2016
    13
    Yeah
    The globe is 6v. Even when I try 6v, direct from the adaptor, nothing. All you can feel is a slight resistance, but no actual turning.
    #8
  9. Hammerhorror
    Bluejets
    Oct 5, 2014
    2,649
    501
    What is the supply voltage reading?
    Sounds like no power.
    Where did you get the "straight from 6v ac" adaptor?
    Perhaps show a few pics.
    Seems it will spin either direction and the "friction" you feel is probably just the gearing.
    Bluejets, Aug 10, 2018
    #9
    1. Advertisements
