george2525
- Jan 30, 2015
- 170
- Joined
- Jan 30, 2015
- Messages
- 170
Hi
Ive been scratching my head for 2 days on this. I hope somebody can help as ive ran out of ideas
Below is an R2R ladder that outputs 0.1V - 3.1V in steps of 0.1V
I need these steps to be scaled down to 0.0015v - 0.465V in steps of 0.0015V (1.5mV steps)
The first buffer seems ok
I then use the inverting op amp with correct ratio but it does not scale properly!
I chose the LMC6001 because it states that is has ultra low current input so I thought this might help a bit
at 3.1V from the R2R it seems to work ok but not at lower values.
I have tried variations such as use of a potential divider from the first buffer to scale the voltage, then buffering that to the rest of the circuit but that didnt work well enough either.
The rest of the circuit is a BJT based exponential converter where the 0.0015V steps are applied to the base of a BJT
I can show this if necessary but doesnt seem relevant now.
Im hoping someone can help as ive hit a brick wall.
Thanks. I always appreciate the advice here
