Problem Uploading the sketch to arduino uno.
Discussion in 'Microcontrollers, Programming and IoT' started by ishan dev, Sep 11, 2017.
  1. ishan dev
    ishan dev
    Jun 26, 2017
    6
    I wrote a sketch on arduino IDE and tried to upload to the board. Had following error while uploading
    Sketch uses 7958 bytes (24%) of program storage space. Maximum is 32256 bytes.
    Global variables use 483 bytes (23%) of dynamic memory, leaving 1565 bytes for local variables. Maximum is 2048 bytes.
    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM11 -b115200 -D -Uflash:w:C:\Users\SBI\AppData\Local\Temp\arduino_build_850591/lll.ino.hex:i
    avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
    Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
    Copyright (c) 2007-2014 Joerg Wunsch
    System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
    Using Port : COM11
    Using Programmer : arduino
    Overriding Baud Rate : 115200
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8f
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8f
    avrdude done. Thank you.
    Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
    Tried google and the steps at different forums, nothing worked for me, also there is no clear cut solution, there is a mix of hit and try, If anyone could lead me in the right direction as to what is the problem occuring?
    #1
    1. Advertisements
  2. ishan dev
    vijaykrishna
    Sep 9, 2017
    35
    3
    vijaykrishna, Sep 11, 2017
    #2
    1. Advertisements
  3. ishan dev
    ishan dev
    Jun 26, 2017
    6
    Tried burning the bootloader this is the log. unsuccessful.
    Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
    Archiving built core (caching) in: C:\Users\SBI\AppData\Local\Temp\arduino_cache_985796\core\core_breadboard_avr_atmega328bb_0c812875ac70eb4a9b385d8fb077f54c.a
    Sketch uses 4418 bytes (14%) of program storage space. Maximum is 30720 bytes.
    Global variables use 483 bytes of dynamic memory.
    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM11 -b57600 -D -Uflash:w:C:\Users\SBI\AppData\Local\Temp\arduino_build_101228/ArduinoISP.ino.hex:i
    Using Port : COM11
    Overriding Baud Rate : 57600
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
    still not working. please help
    #3
  4. ishan dev
    Bluejets
    Oct 5, 2014
    2,255
    445
    Try loading " blink" example and go from there.
    Bluejets, Sep 11, 2017
    #4
  5. ishan dev
    vijaykrishna
    Sep 9, 2017
    35
    3
    do you have one more arduino? if ic is removable, then just replace IC from that and place it in to your problem causing board.
    vijaykrishna, Sep 12, 2017
    #5
  6. ishan dev
    ishan dev
    Jun 26, 2017
    6
    Ok i have ordered some spare ic with preloaded bootloader will check when it arrives.
    ishan dev, Sep 13, 2017
    #6
    1. Advertisements
