PowerCon Connector's / Neutrik
Discussion in 'General Electronics Discussion' started by LightShow, May 16, 2018.
  1. LightShow
    LightShow
    Jun 9, 2016
    111
    17
    Sydney
    Hey All,
    Has anyone had experience with fitting female powercon connectors to power boards / power strips I want to make an easy to transport case for Dj gear where everything is already connected inside and then put a Powercon jack on the outside so i can plug different lengths of feed cable as needed..
    Does anyone Have any experience with These connectors?
    Is there a better way to do this?
    Regards, Lightshow
    #1
  2. LightShow
    kellys_eye
    Jun 25, 2010
    3,961
    1,057
    West Coast, Scotland
    The type and suitability of plug is down to you. Providing it meets the electrical and environmental requirements I suspect there's a gazillion ways to do what you want to do. Pick one!
    Just make sure there's a 'difference' between types - polarisation for one - (so there's no chance of miss-connection) and that externally connecting power sockets are male/female in the right direction (i.e. the live supply should be on a female connector).
    kellys_eye, May 18, 2018
    #2
    LightShow likes this.
  3. LightShow
    LightShow
    Jun 9, 2016
    111
    17
    Sydney
    thanks for the response!
    the connectors are totally shielded both male and female sides so there is no real risk associated with them. they are usually used with professional grade lighting equipment so i thought they would be able to deal with a decent amount of power
    [​IMG]
    LightShow, May 22, 2018
    #3
  4. LightShow
    kellys_eye
    Jun 25, 2010
    3,961
    1,057
    The datasheets will tell you everything you need to know.
    The ones you show look to be ok and capable of handling most normal-day loads - not sure I'd use an all-plastic connector though. If you expect rough-handling or outdoor/public area use I'd go for metal versions.
    kellys_eye, May 22, 2018
    #4
Similar Threads
Loading...
