VXXV said:
do anyone knows how does the Power Noisy Filter work?
And where can find such of information for my research?
Thank You
Line noise filters place an impedance mismatch between the line and
the device, so that noise tends to reflect off it rather than pass
through.
A good source of typical design info is in the datasheets for actual
prepackaged filters. Simulating those designs in Spice will
demonstrate what is going on inside those designs. If the data sheets
do not have values, you may have to take a few filters apart and
measure the component values. The inductors shown with a circular two
ended arrow inside are transformers with two tightly coupled
windings. These can have high inductance (no gaps in the core) for
common mode noise currents (going the same way in each line) because
the differential currents (the normal current that comes in one line
goes through the load and goes back out the other line) produce
canceling magnetic fields that do not magnetize the core. These, of
course present little impedance in the way of normal load current
harmonics.
see:
http://www.corcom.com/
for example:
http://www.corcom.com/pdf/rfi/B Series.PDF
http://www.corcom.com/pdf/rfi/AQ Series.PDF
