Rick Johnson
- May 11, 2016
- 23
- Joined
- May 11, 2016
- Messages
- 23
Im trying to power a Google Home Mini at the end of about 60 ft of wire (4 pr 18 gauge) double the pairs
I have tried
Using a 5v 2amp power supply (at the end the voltage drops below 5v google home will not boot
Using a 5.8v 1.8 amp power supply with a diode or two to drop the voltage the google home will reboot after a few min
Using a 12v power supply to power a USB car charger (5v 2amp output) Google home will reboot but run for at least 10 min
Any suggestions
I was thinking about using a LM7805 Voltage Regulator and power it with 12v. Not sure how much heat that would generate. It would be inside of a wall where I mount the google home
I have tried
Any suggestions
