P
Peter Howard
This is a question about a piece of vacuum tube test equipment commonly used
by amateur radio
operators but as all the ham radio newsgroups I've looked at seem rather
inactive I thought I'd ask it here. I live in a 240Vac mains country and I
have several USA spec GDO's. They are tube types, a Millen, a Lafayette and
a
Heathkit and are of course meant for 110Vac mains which is why I've only
just
got around to doing something to make them usable on 240Vac. A step
down transformer is not the answer. The one I tried put 8.8v on the 6.3V
tube heater. Maybe because the transformer is marked 230V-110V to suit the
nominal 230V Australian mains but in practice the local juice is anywhere
between 240V and 250V.
Each GDO is very similar with a small power transformer and a single half
wave rectifier diode with two electrolytic caps and a resistor for
filtering.. I
replaced electrolytics where necessary and also a defunct selenium stack
rectifier (shows how old the Millen is) and brought them all up on a
borrowed variac to the point where the heaters had 6.3v on
them. The B+ line on all is around 130Vdc, hardly surprising when two are
designed around the same 6AF4 triode and the other a very similar 9002 type.
I have it in mind to power these dippers from a step down power supply
consisting of two identical back to back transformers in a box. They have
multiple taps on their secondary windings and in practice I can achieve a
wide range of AC voltages by selecting the connections between the tapped
secondaries. When transformers with high voltage secondaries are almost
unavailable new, this arrangement is often used by experimenters with tube
equipment of modest current requirements. The heater supply will be from a
separate 6.3V heater transformer in the same box
I have two choices. One is to remove the transformers from the dippers,
leave the rectifier and filter caps in place and bring in the heater supply
and a higher voltage AC feed for the rectifier through a multiwire
connecting cable. The connecting cable with plug and socket are suitably
rated for the voltages and currents involved.
The other is to do the rectifying and smoothing in the transformer box and
make it a DC feed direct to the B+ line in each dipper.
I'm trying to choose between these alternatives and both seem equally good.
Can anyone think of a reason to prefer one method over the other?
PH
by amateur radio
a
just
filtering.. I
PH
