P
[email protected]
Is there any "standard" way to provide power that is more than 802.11af (PoE)
specifies at the power consumer end..?
Asfaik cat.5 cables use AWG 24 which should allow .8 Amps per wire. By useing
them in parallel one should be able to transfer
..8 Amps * 2 wires * 48 Volts = 76.8 Watt. Useing not only the spare pairs in
a 10/100 setup. 153.6 Watt should be possible.
If 802.11af is followed then limit is 12.95W. Which is to little. If a normal
dc/dc converter is used then the required power is supplied (large lcd).
But it will not follow specification.
Any thoughts on this .. ?
