Sir Josiah70 . . . . .
Considering the somewhat hefty weight and the mass of that toroidic inductor, along with the area / compartment being found within.
Is there now a possibility that the unit had either been subjected to rough and severe vibration, or even experiencing a HARD drop?
Or . . . .it even having received a poor or marginal wave soldering at time of manufacture of the stuffed board.
A good reliability procedure on their part, would have been an additional and dedicated hand flow re soldering of , splayed out and bent ends of the inductor.
AND, even further supplementing that, with the use of an adhesive between the inductor proper and the PCB.
Now check out the foil side of the PCB to see if you can find two properly spaced apart holes that are now missing their inductor .
That inductor is probably being used as the MAJOR component in a ringing buck / or / boost power converter.
Ole' crystal ball over there, is glowing, and telling me to also tell you, that lead direction of reinstall / polarity, is not being a relevant issue on the toroid.
Thasssssssit . . . .
73's de Edd
