Please check this for me
Discussion in 'LEDs and Optoelectronics' started by Vagulus, Jun 12, 2018.
  1. Vagulus
    Vagulus
    May 6, 2018
    26
    Perth Western Australia
    This is, I guess, ridiculously simple, but then ... I am just a bumbling beginner. I want to insert an LED into my circuitry so I can tell when it is powered up. I came up with this, but I get all-of-a-tizz when I think of pull-up and pull-down resistors. I want the LED to glow when the power is on:
    Is that right?
    #1
    1. Advertisements
  2. Vagulus
    8,287
    1,560
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Sorry, no. As it is, the LEd will short circuit the 3.3 V supply.
    The LED needs a curent limiting resistor in series, not in parallel. Read this resource for details and equations.
    I also recommend a pull-up resistor from teh reset pin to 3.3 V to ensure logic high level with switch SW1 open.
    Additionally it is always a good technique to add a bypass capacitor (typically 100 nF ceramic) next to the Vcc pin with as short as possible connections to the Vcc pin and GND.
    [Edit: As you are using an Arduino (sorry, I saw that only later) the pull-up and the capacitor are probably in place on the arduino board, no neeed for additional components, tehn]
    Harald Kapp, Jun 12, 2018
    #2
    1. Advertisements
  3. Vagulus
    Vagulus
    May 6, 2018
    26
    Thanks Harald
    I am not trying to control the light emitted by the LED - I believe that is the case for a current limiting resistor. I am trying to ensure that the LED will stop shining when the power supply is off - I believe that is a pull-down resistor. Is that not what I have.
    Might I ask that you draw a schematic of the correct configuration.
    I am assuming that this is taken care of in the Arduino (Pro Mini in this case).
    #3
  4. Vagulus
    8,287
    1,560
    You need to limit teh current through the LED. Otherwise it will burn out or shut down the power supply, whichever happens first.
    That's a natural consequence of missing power.
    Your belief is wrong. Read here.
    Put a resistor in series with the LED, not parallel. Calculate the required value acording to the resource linked in post #2.
    #4
  5. Vagulus
    Vagulus
    May 6, 2018
    26
    I appreciate that lights usually go off when you turn the power off, but one of the first exercises I did when I started working through an Arduino book involved and LED that blinked (ain't that a surprise o_O ) and after a while the LED stayed on when the power was off. My interpretation was that there was some residual current in the circuit which kept the LED glowing - which, of course, could be dangerously misleading in some circumstances. This, as I recollect was solved by using a draw-down resistor which, I believed, siphoned off any residual current and turned the light out reliably. It's that effect I am trying to replicate here.
    I'll go back to that book and your links in the morning.
    #5
  6. Vagulus
    8,287
    1,560
    How so? In that case power obviously was not off, or there was another power source that you didn't take into account.
    There ain't no such thing as residual current.
    The only way current can flow without power being applied is in a superconductor - I doubt your arduino was supercooled.
    The way you apply the resistor is to bleed any charge that may remain on capacitors after the main power supply is off. Usually at low voltages such a resistor is not required as the circuit will discharge the capacitors rather quickly. You use bleeder resistors to discharge high voltage circuits e.g. in a tube TV. Not here.
    Anyway: the series resistor for teh LED is required.
    #6
  7. Vagulus
    jaredwolff
    Jun 11, 2018
    7
    New Haven
    I will just pipe in and agree that the resistor has to be in series rather than in parallel. You'll likely burn out the LED if you leave it in that configuration.
    What color is the LED? You should make sure that the resistor matches the forward voltage. If it's red or green the forward voltage is lower thus a 330 ohm resistor makes sense. If it's blue you may need to adjust that resistor.
    jaredwolff, Jun 12, 2018
    #7
  8. Vagulus
    73's de Edd
    Aug 21, 2015
    2,222
    736
    Texas
    73's de Edd, Jun 12, 2018
    #8
  9. Vagulus
    Vagulus
    May 6, 2018
    26
    Vagulus, Jun 13, 2018 at 3:35 AM
    #9
  10. Vagulus
    davenn Moderator
    12,651
    1,569
    Sydney, Australia
    so in reality, you haven't changed it's position/function as it is still across your regulated 3.3V rail
    davenn, Jun 13, 2018 at 8:31 AM
    #10
  11. Vagulus
    bushtech
    Sep 13, 2016
    709
    119
    Vaalkopdam North West
    Wouldn't a more normal place for the power on led be at the power plug inlet to the board with the appropriate resistor
    bushtech, Jun 13, 2018 at 9:13 AM
    #11
  12. Vagulus
    Vagulus
    May 6, 2018
    26
    As long as you are always going to use the same power supply. :rolleyes:
    Vagulus, Jun 13, 2018 at 11:11 AM
    #12
  13. Vagulus
    Vagulus
    May 6, 2018
    26
    Changed its function because it is now in series. :) It's a really small resistor, but that's what the numbers brought up - and it works fine on the breadboard.
    Vagulus, Jun 13, 2018 at 11:13 AM
    #13
    1. Advertisements
