Hi all new to this forum hoping for some help with me trusty amp. just lately it stopped clicking when tuned on and no sound came out indicating the relay not activating it was intermittent. ive had a go at trouble shooting but now hit the extent of my knowledge.
What a have done so far.
removed the relay and tested continuity. OK
tested the actuator with a separate psu clicks as it should
removed the power transistors. tested with a mm all seems ok. (but im no expert used a guide on youtube to test)
then i tested the voltage on the board across the pins where the relay actuator lives and I get 48v which i found strange as the relay clearly states 24v. idont know where to go from here any input would be great full. thanks.
