Pick And Place Machine (Siemens) Connection Error
Discussion in 'Troubleshooting and Repair' started by kim8268, Aug 10, 2018.
  1. kim8268
    kim8268
    Aug 10, 2018
    Having problems with both s25hm and f5hm model (siemens machine)
    PSTSI - Line control GUI
    Error on station "f5hm". Cause connection to the station is not available
    Error on station "S25hm". Cause connection to the station is not available
    Im a bit of a novice at siemens machine and I only tried checking if the IP address are the same, lan cable and routers but to no benefiting results
    Note. IP on the machine and the IP of the machine in the PSTSI - Line control GUI are the same
    can any one guide on possible remedy to my problem?
    #1
