A
[email protected]
I have 2 questions about PICAXE:
1) my program run executing a loop that do some operations; at the
same time I would like to detect data from infrared sensor by INFRAIN
command. I thought to do this: program run into main loop (not stand
by on IFRAIN) and interrupt is set to pin 0 high (pin enabled to
receive data from infrared sensor). When program detect high level on
pin 0 (begin trasmission) execute interrupt sobroutine (interrupt
detected); here, INFRAIN command decode data received. Otherwise I
could detect interrupt on other pin, connected, anyway, to infrared
sensor.
Do you think it will work?
2) I have to detect if button on IR remote control is held. After each
operation following valid data on infrared pin, before execute next
INFRAIN command, I call a subroutine like this: check pin 0 (infrared)
for high level continuosly (approx. 45 ms). If high level is detected
then button is held. Now execute INFRAIN command again.
Thank you
sensor.
Thank you
