W
Wiebe@CARYA
Perhaps this is obvious, but I'm used to making software, and don't know
enough about hardware to solve this...
I programmed a 12F675 to blink a LED. This runs ok on the picstart
programmer.
Next step was to build a board to run the project. I only connect Vdd, Vss
and the LED/Resistor to pin 1,8 and 3. This works with a lab power supply.
It works for voltages from aprox. 4 to 8 volt.
But when I try a 6V net adaptor it doesn't work. It looks to me like the pic
resets continuously. The adaptor isn't broken (the led always burns). It
looks to me the voltage isn't stable enough. I put a 10nF capacitor over Vdd
and Vss, without success (also tried 4.7uF). I also connected MCLR (pin 4)
to Vdd (directly and with a resistor). Again without success.
Is there any way to get this working (preferably without a voltage regulator
like a 7805)?
Wiebe.
programmer.
like a 7805)?
Wiebe.
