kongyanxiao
- Mar 11, 2009
- 1
- Joined
- Mar 11, 2009
- Messages
- 1
PI3DBV40 Datasheet
Edited b leading IC purchasers' best choice of platform for one-stop valued service!
Description:
Pericom Semiconductor’s PI3DBV series of logic circuits are produced using the Company’s advanced sub-micron CMOS technology, achieving industry leading performance.
The PI3DBV40 is a 8- to 4-channel multiplexer/demultiplexer. Industry leading advantages include a propagation delay of less than 250ps, resulting from its low channel resistance and I/O capacitance. The device multiplexes differential outputs from a video source to one of two corresponding outputs or switches two inputs to a common display. The switch is bidirectional and offers little or no attenuation of the high-speed signals at the outputs. It is designed for low bit-to-bit skew, high channel-to-channel noise isolation and is compatible with various standards, such as LVDS and TMDS.
The above info is from
Features:
• RON is 4Ω typical
• Low bit-to-bit skew: 200ps
• Low crosstalk: –27dB @ 250MHz
• Low Current Consumption: 20μA
• Near-Zero propagation delay: 250ps
• Switching speed: 9ns
• Channel On-Capacitance: 9.5pF (typical)
• VCC Operating Range: +3.0V to +3.6V
• ESD>2000V . . . Human Body Model
• >500 MHz bandwidth (or data frequency)
• Packaging (Pb-free & Green available): 48-pin, 240-mil wide plastic TSSOP (A)
(Absolute) Maximum Ratings:
Above which useful life may be impaired. For user guidelines, not tested.
Storage Temperature....................................–65°C to +150°C
Supply Voltage to Ground Potential...............–0.5V to +4.0V
DC Input Voltage............................................–0.5V to +5.5V
DC Output Current......................................................120mA
Power Dissipation...........................................................0.5W
Note:
Stresses greater than those listed under MAXIMUM RATINGS may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability.
Edited bythe biggest IC PDF and datasheet download site.
Applications:
• Routes physical layer signals for high bandwidth digital video
Pinout:
Description:
Features:
• RON is 4Ω typical
Note:
Applications:
Pinout:
