PCLink Speed
R
R-Guy
What is the speed of the between a DSC alarm panel (like a PC5010) and a
locally connected PC running DLS?
Thanks.
F
Frank Olson
Thanks.
It's just a little faster than you can walk.
R
R-Guy
Thanks Frank. I was hoping for something like 110 or 300 bps.
R
R-Guy
I have a Power832 (PC5010) system and a PC running DLS-2002 SP2. I also
have a Lantronix single port terminal server and their COM port redirector
software on the PC.
I idea is to connect to the alarm panel over the LAN rather than running a
serial cable. The terminal server / redirector software works fine with
other applications, but I have problems getting it going with the DSC
system. I am suspecting that the problem is the link speed. The Lantronix
unit does not support 110 bps (just 300 bps and higher).
Any help would be appreciated.
B
Bob La Londe
Roland Moore said:
Using a PC 5400?
You do realize that plain ol un amplified RS232 with no reapeaters is good
for 75 feet. Why not just take the unused pairs on your net drop and use
them for a serial connection. (Ethernet only uses 2 pairs even though there
are four in the cable.)
Yeah... I know you want to do it over your ethernet.
M
Mark Leuck
My experience is its way faster than that
