Panasonic VCR PV-V4022 ejects after insert
R
RichK
This is not very old vcr, but something failed. The tape will go in and
even threaded, but as soon as it therads the tape cartridge ejects.
Mechanism seems smooth in operation.
I do not find any references to this model and problem. Any suggestion for
those in the know?
Thanks in advance.
Regards,
Rich
R
Ray L. Volts
RichK said:
for
those in the know?
Thanks in advance.
Regards,
Rich
Does the tape unthread and reel back into the cassette before it ejects?
B
b
RichK said:
those in the know?
clean/replace mode switch. check mech timing is OK.
-B
R
RichK
Hi Ray,
"Ray L. Volts" <rote in message ...
Yes, the tape goes in all the right places, but as soon as it does, it reels
back in and ejectes.
The only odd part in this cycle is a "double touch" of the pinch roller on
the right side (takeup in play and FF). It sort of touches, backs up a
couple of mm and touches again, after whch it starts the ejection cycle.
Regards,
Rich
R
Ray L. Volts
RichK said:
Hi Ray,
reels
Regards,
Rich
Could be the mode switch as another poster suggested. Could be an
end-of-tape sensor. Could be the take-up reel not turning (check belts,
rubber drive parts). Let us know...
John T
My Panasonic NV-FJ620 has the same fault at the moment, but sometimes when
the tape inserts, it'll try a couple of times to eject after unthreading the
tape, but after this, the tape will thread again but this time the unit goes
into picture search mode in fast forward - when it does this, the unit acts
like it's locked up. It will not respond to any button pressed whatsoever.
I've been hearing about a mode switch possibly needing a clean - where is
this switch located on these units?
John
R
Ray L. Volts
RichK said:
Hi Ray
an
Does the tape unthread and reel back into the cassette before i ejects
Yes, the tape goes in all the right places, but as soon as it does i
reel
back in and ejectes
The only odd part in this cycle is a "double touch" of the pinc roller o
the right side (takeup in play and FF). It sort of touches, back up
couple of mm and touches again, after whch it starts the ejectio cycle
Regards
Ric
belts,
R
Ray L. Volts
John T said:
the
goes
acts
John
Mode switches are usually located under the main cam gear. This gear is
usually the largest in the assembly. It has a maze of valleys which a pin
rides in; the pin landing in various positions according to function
selected. You won't be able to see the gear's maze until you remove it and
turn it over.
The mode switch is a multi-position, flattish, round switch which is rotated
by the aforementioned pin. As for locating the mode switch, look for wires
that lead under the gear assembly; there will be several wires going to it.
As for cleaning the mode switch, don't be surprised if it's well-sealed and
difficult, if not impossible to get into. Sometimes you can simply spray
cleaner into it -- a plastic extender tube really helps here.
There is a multitude of websites devoted to VCR maintenance and repair; this
page may shed more light for you:
http://www.fixer.com/osm/operations.html
