PAL resolution
Discussion in 'Hobby Electronics' started by Ian, Jul 20, 2003.
  1. Ian
    Ian Guest
    Hi.
    PAL resolution is 768 x 576 pixels.
    1/ Does this mean a large screen tv has the same amount of pixels as a
    portable?.
    2/ SVGA has a resolution of 800 x 600 only slightly better tha PAL
    resolution. Why does it look so much better?.
    Thanks for your help
    Ian, Jul 20, 2003
    #1
  2. Ian
    Phil Allison Guest
    ** No way is that PAL broadcast resolution - there are no pixels as
    such.
    ** The larger screens like 68 cm normally have better resolution of
    detail than 34 cm.
    ** Because there really are 480,000 individual colour pixels.
    The bandwidth available for a colour PAL broadcast signal is only
    4.5 MHz or so while a PC monitor has many times that bandwidth for *each*
    colour signal.
    ............. Phil
    Phil Allison, Jul 20, 2003
    #2
  3. Ian
    Mainlander Guest
    Says who?
    Mainlander, Jul 21, 2003
    #3
  4. Ian
    Phil Allison Guest
    ** Actually the frame rate it is only 25 Hz - the field rate is 50 Hz
    and interlaced to reduce flicker.
    .............. Phil
    Phil Allison, Jul 22, 2003
    #4
  5. DOH!
    Steve Marshall, Jul 22, 2003
    #5
