E
Eike Lantzsch, ZP6CGE
Hi y'all
I was searching the web for some information on PAL-N (Argentina) and
PAL-Nc (where?). What I got was this:
PAL (Combination N) [country?]
Line/Field = 625/50
FH = 15.625 khz
FV = 50 Hz
FSC = 4.43361875 Mhz
Blanking Setup = 7.5 IRE
Video Bandwidth = 5.0 Mhz
Audio Carrier = 5.5 Mhz
Channel Bandwidth = 7 Mhz
Video IF-Frequency = ? MHz
PAL (N) [Argentina]
Line/Field = 625/50
FH = 15.625 khz
FV = 50 Hz
FSC = 3.58205625 Mhz (Burst Frequency)
Blanking Setup = 0 IRE
Video Bandwidth = 4.2 Mhz
Audio Carrier = 4.5 Mhz
Channel Bandwidth = 6 Mhz
I'm not sure if this is right because the site seemed to have confused
the countries.
Can anybody confirm the data?
What are the IF-frequencioes used for PAL-N and PAL-Nc?
Your help will be very much appreciated.
Thank you
Kind regards, Eike
Line/Field = 625/50
FH = 15.625 khz
FV = 50 Hz
PAL (N) [Argentina]
Line/Field = 625/50
FH = 15.625 khz
FV = 50 Hz
the countries.
Thank you
Kind regards, Eike
