Categories
Platforms
Content
2 legs or 4 legs crystal oscillator for depth measurement application???any other freq gen option??
In case you are interested in a detailed and comprehensive answer it would be wise to spent a bit more time for explaining your problem.2 legs or 4 legs crystal oscillator for depth measurement application???any other freq gen option??
Why don't you post links to the web pages where you found 200 kHz oscillators with (1) 2 legs and (2) 4 legs. A part number and name of manufacturer would also help us to recommend something for you.actually wht i am trying to do is to measure yhe depth of water, for which i need to generate a transmission signal of 200khz using oscillator.when i go out to buy it i found 2 types
1)2 legs
2)4 legs
i am confused that which one will work better and staable>???
Guessing he's after making an echo sounder - 200kHz being a common transducer frequency.How do you propose to use a 200 kHz oscillator to determine water depth?
