Hi I was wondering how would you connect an or gate to a shift register? Thanks
K kingofjong Aug 14, 2014 30 Joined Aug 14, 2014 Messages 30 May 20, 2018 #1 Hi I was wondering how would you connect an or gate to a shift register? Thanks
Alec_t Jul 7, 2015 3,590 Joined Jul 7, 2015 Messages 3,590 May 20, 2018 #2 I'd use a length of wire or a PCB trace.
hexreader Apr 21, 2011 135 Joined Apr 21, 2011 Messages 135 May 20, 2018 #3 Alec_t said: I'd use a length of wire or a PCB trace. Click to expand... I am not sure that those alone are enough. I would use solder as well. ... but I suspect that the OP is looking for a completely different answer. Beyond me what the real question is @kingofjong - can you give a clearer question please? Which shift register (part number) and why do you want to connect an OR gate to it?
Alec_t Jul 7, 2015 3,590 Joined Jul 7, 2015 Messages 3,590 May 20, 2018 #4 hexreader said: I suspect that the OP is looking for a completely different answer Click to expand... I'm sure they are .
BobK Jan 5, 2010 7,682 Joined Jan 5, 2010 Messages 7,682 May 21, 2018 #5 An output of one to an input of the other. Bob
K kingofjong Aug 14, 2014 30 Joined Aug 14, 2014 Messages 30 May 23, 2018 #6 Thanks for all you replies. I finally got it to work.
K kingofjong Aug 14, 2014 30 Joined Aug 14, 2014 Messages 30 May 23, 2018 #7 Thanks for all your replies, it helped a lot. I finally got it to work.
