Op amp problem
Sean Douglas
Nov 6, 2017
Nov 6, 2017
So I'm using an lm358 op amp as an inverting amplifier and for whatever reason I'm not getting anywhere close to the results I'm looking for. I have calculated the gain to be -10 with an input voltage of 1 volt. And a 15 volt power supply on the power inputs. Im getting an output voltage of around 160 mV with a clipped off negative sine wave on my scope. I am baffled by this.
Bluejets
Oct 5, 2014
6,920
Oct 5, 2014
6,920
I would say that without at least, some circuit drawing with details, most others here will be also.
7,682
7,682
So at 1V the output should be -10V. How do expect to get that when the power is a single ended 15V?
You need dual supplies to get negative voltages out.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
Need a sketch of some sort to determine what you have done.
Harald Kapp
13,719
13,719
I'M absolutely with Bob.
Note that the output of the LM358 can go to the negative rail (V-), but is limited to the positive rail (V+) -1.5 V.
