Op-amp circuit of an electronic card for a turbine flow meter (m3 Counter)
Dadou
Feb 24, 2018
Feb 24, 2018
Hi!
This circuit is part of an electronic card used as an interface in a flow meter. An inductive sensor which operate without being powered counts the rotations of the turbine; then transmits the signal to the pins 24,pin25 and shield of the circuit (Refer to the picture). The output of the op-amp drives a "Nand" Cmos gate. Note that there are two similar circuits as there are two sensors:eek:ne on the x-axis and the other to the y-axis. Each sensor is connected to a separate circuit similar to the one shown.
I whould like to know if the circuit is a linear or a non-liear op-amp application and the operation of this circuit?
Thank you in advance for your time and consideration.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
There is no DC connection to the op-amp -input so the output could be anything.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Yes there is.
The components at the bottom of the (poorly drawn) schematic are effectively across the op-amp inputs and there is a connection to Vcc through R5
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Yes there is.
As I see it, C3 blocks any DC connection.
D1 and D2 are back to back diodes, presumably to limit the differential voltage across the op-amp input, but they are not connected there.
Agree with a very poor schematic layout.
