Richard9025
- May 24, 2016
- 205
- Joined
- May 24, 2016
- Messages
- 205
Hi
About a week ago , I got a vintage romanian radio , from '89 named Gloria 4 rp 1524 made by TEHNOTON
http://www.radiomuseum.org/r/tehnoton_gloria_4_rp_1524.html
Now , some little history about this radio
First day that I got it , it was working on all the bands , good audio , except some problems (30min of usage that day)
- all the time there was a strong hum (only when connected to the wall socket)
- the on/off switch wasn't working (volume potentiometer can also turn on/off the radio)
- the light switch wasn't working
About these problems I can tell you that someone disconnected the lights from the circuit and bypassed the power switch
Second day it was all the same , except that on the SW2 band it had little distortions on weak stations . (1-2hr of usage that day)
Third day - the problematic day - , verrryyy strong distortions on all the signals (and all bands) , i couldn't understand anything (weak&strong stations) and , after 5 minutes of staying on , the volume slowly started to get lower and lower until , after 2 minutes it got completely silent , it only maked a "bum" (<half of a second) everytime i turned it on . (30 min of usage that day )
Now , it doesn't even make that bum , completely silent (AC and batteries) ... (but there is voltage in it)
So , I thought that an electrolityc capacitor in the af block and replaced the bigger ones
Schematic with the replaced capacitors (in red squares) (somewhat translated from romanian to english)
https://goo.gl/photos/hQmER8gAx3pLxZaW9
Also , with a 0,1uf poliester cap , an rca cable and some wires , I injected the audio from the intersection of r326 and r327 into a tv av input and nothing , no signal from the origin of the am detected singal . (the problem isn't in the af block)
I'll make some photos of the patient after I get a good camera
