old extension amp to guitar amp
phil.m
Mar 26, 2013
Mar 26, 2013
hi.
i have an old murphy radio extension speaker cab amp. that i would like to convert for use with an electric guitar.
bearing in mind that i am an electronics virgin.
could you adise on the best way to tackle this project please
thanks phil.
i have attached 2 jpegs. as you will see it is a tube amp.
i dont know what other info to give to help you to help me.
so in the first instance i'm hoping for questions.
thanks
phil
7,682
7,682
Personally, I would replace the amp with something for a few bucks off Ebay.
Edited. If you insist on using this amp, you probabably need only to add a preamp. Google "guitar preamp" for ideas.
phil.m
Mar 26, 2013
Mar 26, 2013
thanks for the reply bob. i do have other amps but i live in a flat with thin walls and ceilings so have trouble getting tone out of my other amps at low volumes. so would like to give this a try.
my pics are blurry so will add some more with a bit more detail soon. i need to understand this circuit, but to ypu it dosent look as though there is any pre amp. guess that makes sense..
7,682
7,682
Have you verified that the amp works at all? Will you get sound out if you connnect the amp's input to the out of an MP3 or CD player? It is likely designed for that kind of a level in. A guitar puts out a much lower signal, more like a microphone.
