[email protected] wrote in
My favorites were the Mica Capacitors. I'm still wondering how they
were made, and how were the wires attached? I just liked the look of
them with all the colored dots on them. Listed on site below as well
as pictures of them.
http://www.sayedsaad.com/fundmental/14_Fixed Capacitor.htm
In an article (below), they mention the Silver Mica caps (which came
out later). It says they were plated. How does one plate mica? And
how does one get the right thickness of mica, knowing how it's all
random pieces.
I made ceramic capacitors in the late 60's and early 70's for Sprague
Electric co. so I can make some guesses as to how the micas were made,
or tell you how I would do it.
Mica comes in large sheets that are rather uniform in thickness.
I would use a chemical reaction
http://www.finishing.com/0400-
0599/415.shtml to plate the mica on both sides and measure the
capacitance of the large sheet.
From that value, I would know what sizes to cut the sheet into in order
to make many mica capacitors of 'about the desired value'.
I would then cut the sheet up into a bunch of small capacitors, solder
on leads, and then use injection molding to make the case.
Of course, each finished capacitor would be tested for value and the
actual value put on the case.
We did something rather similar when making ceramic capacitors. We had a
target value for the batch we were making, used silk screen printing to
print patterns of electrodes onto a layer of green[unfired] ceramic
laid down another layer of ceramic slip, printed more electrodes,
continued until we had enough 'area' to give the desired cap. We would
then break up the sheet into hundreds of 'green' capacitors, 'fire' them
in a kiln, abrade the edges to expose the electrodes, dip the ends in
conductive ink and bake it on, solder on leads and cover coat.
We would then test them for value and stamp them.
But the article does not mention the make-up of the
original Mica Caps.
http://www.radio-electronics.com/info/data/capacitor/capacitor_types.ph
p
And what the heck is Tantalum?
An element. A metal. Right under Niobium and Vanadium in the periodic
table, between Hafnium and Tungsten.
It can be used to produce a rather high value electrolytic capacitor as
aluminum is still used for some electrolytic.
