M
mooseo
I'm building a temperature control circuit, and am having some weird
noise issues. The basic idea is that I have LM35s (eventually 24,
currently 3 of them) reading the temperature of water baths. These are
switched by a 4052 multiplexer, run through an instrumentation amp and
then read by a computer DAQ system. The circuit has a simple low-pass
filter, and I am reading each channel at about 0.4 Hz. The computer
calculates the output needed to keep the temp at the desired level, and
switches a relay to control a heater. (Lots of thanks to the people
who helped me get this circuit working earlier in the week).
In theory, everything works. The LM35s are encased in 2 layers of
adhesive-lined heat shrink and submerged in the water baths. When they
are dry, they work fine. When they are submerged, they work fine. At
some point, however, they eventually start picking up some noise. It
could be from the relays, although I've noticed that dumping ice into
the bath can sometimes trigger it. From that point, on, the output is a
mess, even when I unplug the relays from the AC and stop switching
them. The only thing I can do is pull the probes out, dry them out
(nothing fancy, just dab them on my shirt), turn the circuit off and
then on again and start over. When I do this, everything is fine.
My first thought was that the probes are getting wet, but they aren't
drifting and they work fine when they are just sitting in water.
My other thoughts were that the relays were putting noise into the
circuit somehow, but it persists even when they are no longer
operating.
Does anyone have thoughts of things I might try to understand this?
The circuit diagram is here:
http://www.moosecraft.org/TURD/mux_board_with_amp_rev2.jpg
Thanks!
mike
operating.
Thanks!
mike
