No power
Status
Not open for further replies.
Syam
Apr 4, 2018
Apr 4, 2018
Im using SA 46.
No power turning on.
But Battery section functioning properly.
Adapter is new one checked and confirmed that its in good condition.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Is the polarity of the (new) plug the same as the old?
Many battery/mains powered equipment have a power plug that is CENTRE-PIN-NEGATIVE whilst most modern power packs have a CENTRE-PIN-POSITIVE connection.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Im using SA 46.
And what is your question?
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
SA 46 might be a Casio keyboard. If so the manual at the following link indicates that it uses an an external tethered-brick style AC/DC 9.5VDC adapter to run off mains AC power.
Use a multimeter to determine if the adapter is outputting close to 9.5V. If it is, which seems to be the case based on the initial post, plug it into the keyboard and measure whether it is maintaining 9.5V, which may require partially dismantling the keyboard.
If it maintains 9.5V, trace the circuit to see where the power stops. The problem might be something as simple as the power input socket having a broken solder joint. If that is the case, determine if the copper trace to it is intact or whether it needs glued down or a jumper wire and possibly epoxy used to fit the socket in place and complete the circuit to the next point along the trace.
http://support.casio.com/pdf/008/Web_SA46_47ES1C.pdf
HellasTechn
Apr 14, 2013
1,579
Apr 14, 2013
1,579
and what is a SA 46 ??
It is so annoying when someone can not spend one more minute to explain what exactly is the device he is asking about or what the actual problem is but instead they expect you to already know the answer of their question to be posted.
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
This inability to post sufficient information and/or form a structured sentence describing the problem(s) appears to be a growing trend...... milleniums perhaps? :D
davenn
14,262
14,262
agreed
thread closed to stop any more time wasting
Status
