R
Ray di Tutto
When trying to tune the final amp on my Kenwood TS-820, I get little or no
plate dip.
The amp can be tuned though, but I only get 50 W HF out, instead of 100 W.
Plate current is nominal at 250 mA and 800 V on the 6146B anodes.
I made these measurements with the rig connected to a 50 ohms dummy load
and the HF output was confirmed with a HP 432A power mwter.
So I get 50 W HF out for 200 W DC in. Efficiency is terrible at only 25%.
All the missing HF power must be dissipated in the anodes because they glow
red after a few seconds.
The same thing happens on all bands. Sometimes, when trying to tune on 7
MHz, plate current gets higher than 350 mA and the rig fuse blows.
I suspect there must be something wrong in the tank circuit.
Upon visual inspection, nothing looks charred in there. No arcing noises.
I checked the plate capacitor, which is OK. I unsoldered it and measured it
@ .001 uF, as it should be.
So I am wondering where to look next. Any ideas?
many tnx in advance
Angel Vilaseca HB9SLV
plate dip.
many tnx in advance
