Hello - I have an old recumbent exercise bike that uses AA batteries, but the battery compartment doesn't contain the connectors. So, I went to Micro Center and found a couple of different "battery holder 2XAA snap" that I thought might work. Unfortunately, the snaps were both too big to fit properly and the only thing I need are the connectors. I think I need a positive and negative connector with wiring on one end and just the positive/negative connectors for the other end. I located a B+ and B- "hole" to connect the wires to, but what is the "goop" stuff that makes the connection hold when placing the positive & negative wires to the board, or whatever the proper terms are...sorry, I'm a step prior to a novice in correct terminology.
Any thoughts or suggestions for where to locate the items needed to make an honest effort to fix?
I could take pictures if that would help, just let me know.
Thanks!!
Thanks!!
