Nest Protect gen 2 POE
Discussion in 'General Electronics Discussion' started by StealthRT, Jul 10, 2018.
  1. StealthRT
    StealthRT
    Sep 4, 2010
    129
    Hey all i am looking for some advice in how to go about my project with a Nest Protect gen 2.
    In my home i have ran cat6 wire to all 3 locations that require a smoke detector. These cat6 cables are connected to a POE switch for powering the Nest Protect.
    The version i picked up for the Nest Protect is the battery version. I am wanting to convert the battery to the POE in order to power it by POE instead of battery. The Nest Protect uses 6 x AA batteries that equal ~9vdc total.
    [​IMG]
    I am converting the POE to 9vdc via a converter:
    [​IMG]
    However my question is- do I need to wire up the 6 battery placers in parallel or series? It would seem that the Nest Protect AC version has only 3 x AA for power backup. Not sure if that matters in my case or not.
    I would like to keep a battery backup just in case the POE goes out for whatever reason. The POE has a battery backup as well.
    #1
    1. Advertisements
