Needed Clarion DRB4375R front panel datasheet
Cevi
May 27, 2016
19
May 27, 2016
19
Hi guys i need the datasheet for the front panel of this car stereo since few years ago I've damaged it quite well.
I'll post a pic from it so you can laugh. :)
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
Sir Cevi . . . . . . .
Will this let you finally get those foil paths and pads repaired ?
73's de Edd
Cevi
May 27, 2016
19
May 27, 2016
19
73's de Edd Thank you sir. I got this datasheet once before and it is totally enough for sure. But I was hoping for the imprinted scheme from the board since there are a lot of broken leads as you can see from my pic and few parts missing. If i can somehow generate a new one it will be great. Aren't there some software that can do this kind of stuff? To virtually rebuild the whole motherboard with the parts on it?
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
We KNOW that one of these units will have what you need.
But is this face plate a security type of thing, that you lift off and carry with you, so that no one will be wanting to steal the remaining faceless radio?
Therefore, the removed "Faceplate" would be having the whole keypad behind it ?
And this item is not just being merely a frontal plastic bezel that you would need, if it gets all cracked up.
http://www.ebay.com/itm/Clarion-drb...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
http://www.ebay.es/itm/CLARION-DRB4375-Detachable-Replacement-Car-Stereo-Face-Plate-/360858201585
http://www.ebay.com/itm/Clarion-DRB4375-Faceplate-Excellent-Condition-/310395575440
You can figure that the timed out / no sale unit still might be available, if you just contact him through another
item that he is currently selling.
73's de Edd
Cevi
May 27, 2016
19
May 27, 2016
19
Yes, this is the frontal plate indeed which you take out for security reasons. The links that you've posted are from the Clarion DRB4375 which almost identical with mine which is a Clarion DRB4375R (Has "R" at the end). The difference is that huge "BAND" button which might be a single switch or a combination of three different buttons because in my case I have 3 different buttons. Here is a link from the "R" version which I have.
http://img.abrakaba.com/004EF8F3-0/Facade-pour-autoradio-Clarion-DRB4375R.jpg
I know that buying a new one will fix my problem but I was thinking that since it's not in such a bad shape I wight fix it. All i need is the scheme of the parts mounted on it and all the correct leads.
