Need help with wiring an electric motor
kisuke47
Feb 28, 2018
Feb 28, 2018
Hi I'm new to these forums and hope to get some help I have an old baldor motor I would like to wire up its a single phase ac motor I'm trying to wire it for 115 volts it has a wiring diagram on the motor it says connect wires 1 3 8 and wires 2 J 5 which I have already done each of the wires are in there respective groups connected with wire nuts in the pictures I have them up and out of the way so you can see better so my question is where do I connect my positive and negative wires too from my power cord? and what do I do with the number 4 wire that's just hanging there? any help would be great thanks.
Bluejets
Oct 5, 2014
6,939
Oct 5, 2014
6,939
Can't see the diagram and it is out of focus.
Try like another poster did here, light the subject via other source and turn off the flash.
Try to use some form of punctuation to make your request readable.
Tha fios agaibh
Aug 11, 2014
2,252
Aug 11, 2014
2,252
L1 (hot) ties to 1,3 and 8
L2 (Neutral) ties to 4
2,5 and J tie together
Don't forget the proper overload protection and ground.
