Need help to fix old RC controller
Discussion in 'Microcontrollers, Programming and IoT' started by Ralf Kalkuhl, Dec 13, 2016.
  1. Ralf Kalkuhl
    Ralf Kalkuhl
    Dec 13, 2016
    7
    I dont know anything about circuits i just need help to solder the negative wire back to the board i just dont know where to solder the wire on the board any help would be appreciated.
    #1
    1. Advertisements
  2. Ralf Kalkuhl
    7,960
    1,457
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Show us an image of the back of the pCB.
    It may also help to know which chip is under the label "Modul Nr. 40018" as knowing where the chip's ground pin is helps identifying the trace to the wire pad.
    Harald Kapp, Dec 13, 2016
    #2
    1. Advertisements
  3. Ralf Kalkuhl
    Bluejets
    Oct 5, 2014
    2,255
    445
    Good chance that the negative sign (-) on the electrolytic capacitor will be the negative rail.
    It's the can looking device between D3 and R8.
    Nice clear photo of the reverse side of the board would help also.
    Bluejets, Dec 13, 2016
    #3
    Harald Kapp likes this.
  4. Ralf Kalkuhl
    7,960
    1,457
    Good hint.
    #4
  5. Ralf Kalkuhl
    Ralf Kalkuhl
    Dec 13, 2016
    7
    Here's a pic of the back and the chip
    #5
  6. Ralf Kalkuhl
    Ralf Kalkuhl
    Dec 13, 2016
    7
    thanks guys i actually got it working again the ground rail was on that can thing
    Ralf Kalkuhl, Dec 14, 2016
    #6
    1. Advertisements
