32Vwasbetteronboats
- Feb 18, 2017
- 80
- Joined
- Feb 18, 2017
- Messages
- 80
www.google.com/search?q=air+conditioner+thermistor
What I am hoping to do is outsmart the people at the place I work who believe if they turn the thermostat on the window ACs down to 60 degrees they will blow colder. I try and explain the machine turns on or off based on temperature and that turning it down won't make it any more on then it already is. They turn it down to 60 then go out all day. I am in Florida.
If I was to add the proper resistor in series with the thermistor I should be able to make a setting of 60 degrees act like 70 right ??
I want to make a deal with the owner of this place that if I can lower the electric bill by $800 I can get the rent on my boat slip behind the place waived. We have about 15 window units, the central air thermostats will need rigging to but many are mercury tilt.
Any ideas to outwit the AC dimwits are also welcome, thanks.
