Need help or excerpt from manual(s) for Fluke 6071A Synth Sig Gen
T
Torin Walker
Greetings,
If you have the operator's, service, or calibration manuals for a Fluke
6071A 200kHz - 1040Mhz Synthesized Signal Generator. I could really use your
help. My unit appears to be broken; it has two flashing indicators, AMPL and
UNCAL, and there is no output coming from the unit. I have enough experience
with this unit to know it is not working correctly.
I would appreciate if you could look into your manual and tell me what they
say regarding these two indicators, and/or what the unit should show when it
first powers up. Mine shows:
607 1 1360
On the middle and rightmost displays. In a previous post I suggested this
might be a model number and error code, but it is more probably a model and
firmware revision level or other non-error code.
When I press interrogate, the rightmost display (the amplitude indicator)
shows 004.
Any help at all would be appreciated.
Torin...
C
Chaos Master
Torin Walker stated:
Greetings,
I have never used a Fluke device, but maybe "AMPL" means amplifier and
"UNCAL" means "uncalibrated"?
[]s
Chaos Master®, posting from Canoas, Brazil - 29.55° S / 51.11° W
"People told me I can't dress like a fairy.
I say, I'm in a rock band and I can do what the hell I want!"
-- Amy Lee
