Need help !! LDR night light
Mr.K
Apr 28, 2016
22
Apr 28, 2016
22
Hello there.
I found a circuit guide to make a LDR night light. I have got a question :
the 10K resistor reduces the brightness of LED quite remarkable. I tested with lower resistors , even less than 1K resistors. Brightness increases as resistor lowers , but the problem is that it also reduces sensitivity of LDR. I mean If I use a 1K resistor , for instance , then the LDR needs too much brightness of light to turn the LED off.
What to do ?
* I don't use a resistor between LED and power source (in the picture which is marked as "If needed")
* I use 7-millimeter LDR . All other specifications are similar to the photo of circuit I attached
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Select a more sensitive LDR, they are all different. Mine have sensitivities of 10 to 1.
Select a transistor with a higher hFE at high currents like a 2N4401 or a darlington transistor then the base resistor value can be higher.
Use a resistor in series with the LEDs to prevent them from burning out.
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
You will get more even illumination and longer LED life if you have one current limiting resistor for *each* LED. Also, you are not going to get very "snappy" response from a single transistor circuit with no hysteresis. Consider two transistors, with at least one of them being a 2N7000 or 7002.
ak
KTW
Feb 22, 2015
273
Feb 22, 2015
273
I built a night light using an LDR enabled PIR sensor so it only operates when activated.
It has to be quite dark to work.
