Need help keeping a rigid mechanism in a 60ºC(140ºF) Incubator
Discussion in 'Power Electronics' started by stopfortheklopp, Oct 11, 2018.
  1. stopfortheklopp
    stopfortheklopp
    Oct 10, 2018
    I've built an incubator with an electrode at the center with the purpose of cell culture, screwing a block with copper tape at each of the ends of the electrode to pass current, but given the fact I need the incubator to have a temperature of 60ºC the nuts and bolts come flying out when I reach that temperature. How would you prevent it? adding weight to the blocks? changing the types of bolts? or what would you change in the design? Here is an very rough schematic of what I'm talking about. https://i.imgur.com/HkY7kSS.png
    Any help is greatly appreciated
    #1
  2. stopfortheklopp
    24,613
    2,495
    Clip the wings of the nuts and bolts. They should stop flying.
    I don't understand your problem and I wonder if you need two threads. Isn't this similar to your other thread?
    (*steve*), Oct 11, 2018
    #2
  3. stopfortheklopp
    duke37
    Jan 9, 2011
    5,056
    675
    Derbyshire. UK
    You could screw up the bolts till they reach the yield point. Alternatively include a Belleville washer to maintain the force as the dimensions change. Use locking nuts to stop them spinning.
    duke37, Oct 11, 2018
    #3
Similar Threads
Loading...
