Hi guys. I am an electronic n00b here and while modifying the case of my cool new battery charger to add cooling vents (I felt that the charger running around 140 deg was a bit too warm), I slipped with the drill and unattached a leg from the pictured resister. I have put in 2 separate orders and have received 2 incorrect products. The first order attempt was my fault as I ordered the incorrect ohm variable (33.3ohn instead of 3.3ohm). For my second order, the units I received were approx 1/4 the size of the one i need replaced. In a humble attempt to stop this nonsense, Im seeking some help identifying the below resistor. If further measurements are needed, I can take more pictures and post them up. Thanks guys.
