Warren Savary
- Jun 15, 2017
- 2
- Joined
- Jun 15, 2017
- Messages
- 2
I recently purchased a Pluto Trigger device for my photographic pursuits (you can see the unit by searching the web for "Pluto Trigger") Among its features is the ability to trigger a camera (or flash) when a laser beam is interrupted, which is one of the things that prompted my purchase. The unit even comes with a small laser emitter for that purpose. The instruction manual suggests an even more elegant modification that would be particularly helpful to me in photographing small pollinators:
"Laser Cross Beam Sensor: Build a DIY light sensor and plug it into Aux port of Pluto Trigger. In Aux mode, set trigger mode to "Low Trigger" and adjust the sensitivity when laser beam aligned. Go to Laser mode, adjust sensitivity when laser beam is aligned. Finally switch to Fusion mode, "AND" Aux mode with Laser mode to set up a laser cross beam sensor" There is a YouTube video that shows such a setup in action.
I'm told by the manufacturer that "You just need a led, a resistor and a cable [I presume a 2.5mm audio cable] to make the light sensor.", with no further guidance. Alas, I am a biologist, not an electrician. HELP!!! Can anyone offer some guidance on how to build the requisite sensor??
