I am looking to build a circuit that has a battery which can be charged in 20 minutes (so it can charge at a rate of 9 amps) with a energy level of 15Wh. Ideally the battery would be a 5v battery and have a capacity of 3000 mah. The discharge of the battery can be much slower (.5 amps).
I would like to keep it a fully DC circuit and if needed I could use a battery that is 12v (or similar) if those do a better job of being charged at the higher rate (I guess with a 12v battery it would just charge at 3.75A). I assume I would just need a transistor or resistor to step the voltage down to 5v for use.
I have a background in Mechanical Engineering and this is just a side hobby project. Any help is greatly appreciated. Looking for help on: feasibility, issues I may run into, types of batteries to use (Li-ion?) and voltage to use.
Thanks!
Thanks!
