H
HappyHobit
Hi All,
I'm building a motor controller for an electric bike. The circuit I found
uses a microcontroller, a 4N35 Opto-isolator and N-channel Mosfets. I like
micros and want to do voltage and current monitoring.
The problem is microcontroller has to turn the 4N35 ON to turn the
Mosfets OFF. I don't like that. If the 4N35 or the 5 volt supply fails
the
Mosfets turn on FULL.
I was thinking of using P-channel Mosfets. (And of course appropriate
circuit and logic changes)
Is there any prevailing reason to use N-channel rather than P-channel
Mosfets?
Thanks for any enlightenment you can provide.
Jay
the
Mosfets?
Jay
