Steve Peart
- Sep 16, 2015
- 53
- Joined
- Sep 16, 2015
- Messages
- 53
Hello All,
I am putting together a circuit board for a project that will plug into my Raspberry Pi with a ribbon cable to provide motor control for 3 separate motors using a hobby battery that's 7.4v 1900maH.
I have gone through 2 other iterations, attempting to build it first with all jumper wires (fail), then I used a blank protoboard with copper tape circuit lines (worked ok but crossed a wire and fried my RPi)
Now I am attempting to build the circuit using the Copper Board with the Ferric Chloride solution, transferring the design to the board with a printout on tranparency paper, and ironing it to the board before immersing it in the chemical solution.
I have no clue how to use the PCB software that's out there, but I am ok with Adobe Illustrator, so I decided to design it there.
Here's the resulting design, I have put in a legend to show what is what on the board, knowing I will have to print it out all black before transferring it to the PCB:
Couple of questions:
1. When I print this out, will it transfer to the board well and also come out with clear line separation after the chemical bath? I am worried about the lines being so close together.
2. In my last board iteration, I failed to implement circuit protections which is likely how I fried my Raspberry Pi. I looked up how people do this and came up with the Zener Diode + Resistor method, so the lines can't spike above the 3.3v Zener as it will ground any extra voltage. The resistor will limit the current going through the line so as to not allow a current spike to destroy things as well. Is this sufficient?
Don't hesitate to ask for more info if you want, I really want to get this right before committing it to the PCB with the solution. The actual size of this circuit is roughly 2in width X 1.5in height.
Any help is appreciated!
Steve
Steve
