MOSFET Issues
Discussion in 'General Electronics Discussion' started by jereburke, Feb 12, 2018.
  1. jereburke
    jereburke
    Feb 12, 2018
    6
    Hey guys, I attached a circuit schematic for my problem, it's simple but I can't seem to find the issue. I want to be able to discharge a 3.8V lithium ion battery over the resistor. I used a 1 ohm resistor so I should get ~3.8A (little lower due to the resistance of the MOSFET,) but it's limited at 2.2A and I'm not sure why. I even tried using a 0.05ohm resistor which should yield significant higher currents, but that capped at 2.7A on full duty cycle.
    Anyone know why I can't get desired currents?
    EDIT: The MOSFET for reference is a IRLZ44N (logic level)
    #1
    1. Advertisements
  2. jereburke
    KMoffett
    Jan 21, 2009
    677
    65
    Minnesota USA
    Do you get 3.8A if you connect the battery and resistor in series, without the MOSFET? What happens to the battery voltage under the the 1Ω load?
    Ken
    KMoffett, Feb 12, 2018
    #2
    1. Advertisements
  3. jereburke
    jereburke
    Feb 12, 2018
    6
    It will discharge at 3.8 amps if I ignore the FET
    #3
  4. jereburke
    7,212
    1,504
    Worcester, MA
    Do you have a common ground between the pulse source and the gate?
    What is the voltage of the pulses?
    BobK, Feb 12, 2018
    #4
  5. jereburke
    Nanren888
    Nov 8, 2015
    39
    6
    "ignore"? remove?
    So you measured this value with a meter?
    This is a good battery if it does not drop at all under load.
    The pulse is referenced to the same ground?
    Seems if everything is right, then there is something else going on. Your hookup wire is ok for 4 amps?
    Nanren888, Feb 12, 2018
    #5
  6. jereburke
    KMoffett
    Jan 21, 2009
    677
    65
    Minnesota USA
    Have you tried just driving the gate with a higher fixed Vg...like +12v?
    Ken
    #6
  7. jereburke
    Bluejets
    Oct 5, 2014
    2,651
    501
    What is your definition of " full" duty cycle?
    Bluejets, Feb 12, 2018
    #7
  8. jereburke
    jereburke
    Feb 12, 2018
    6
    Basically using an arduino and writing the pin high
    jereburke, Feb 13, 2018
    #8
  9. jereburke
    jereburke
    Feb 12, 2018
    6
    yes i do
    #9
  10. jereburke
    jereburke
    Feb 12, 2018
    6
    yes remove. and i'm using 22 AWG jumper wires so it should be good for 4 amps
    #10
  11. jereburke
    jereburke
    Feb 12, 2018
    6
    Hi Ken, I just gave it a try and still getting the limited current. Is there a chance the MOSFET isn't functioning properly?
    #11
  12. jereburke
    24,384
    2,416
    Is the mosfet getting hot?
    Can you read the voltage across the MOSFET while it's on with this load?
    Likewise can you measure the voltage across the battery?
    If you're doing that, you might as well measure the voltage across the load as well.
    In all cases, measure as close to the device as possible to prevent errors caused by the resistance of the leads caring the load current.
    (*steve*), Feb 13, 2018
    #12
  13. jereburke
    WHONOES
    May 20, 2017
    499
    91
    Oxfordshire
    Try putting at least 5vdc on the gate and see what happens.
    WHONOES, Feb 13, 2018
    #13
  14. jereburke
    AnalogKid
    Jun 10, 2015
    2,172
    615
    Ohio - GMT-5
    1. What is the voltage across the MOSFET drain-source pins when it is turned on by applying 12 V DC to the gate-source pins?
    2. Check your pinout. If the FET is in the circuit backwards, the battery is discharging through the body diode. This will reduce the discharge current.
    ak
    AnalogKid, Feb 13, 2018
    #14
    1. Advertisements
