mos transistor modelling
hi,
I'm looking at modelling of the process variations in mos
transistor at say 90nm and below. I'm new to this group, and
not sure where exactly to post it.
Basically, the foundry guys give the standard deviation
data on vt, transconductance and Idss. With this I would like
to figure out how the (say)inverter delays are affected.
(Essentially try and figure out the distribution).
In my opinion, all the three are not totally uncorrelated
to each other. So, I presume selecting two of these should
do a good job. Is this on the right track??
And if someone has worked on these things can he/she share
some basic ideas with me??
ganesh
K
Kevin Aylward
hi,
I hope you mean by using spice. Any other way is daft.
Standard i.c. design practise is to do worst case runs of strong/fast,
nominal/normal and weak/slow. See for example,
http://www.anasoft.co.uk/worstcase.html and
http://www.anasoft.co.uk/WCSETUP.GIF
You need to vary the mosfet capacitances as well.
If you use SS, you only only have to specify two special "multiplier
models", and runs are all automated for that device. You don't have to
work it out yourself.
multiplier are values that multiply nominal values, e.g.
..MODEL ss_wc_nch_xw nmos(tox=1.033 vth0=1.25 cj=1.05 cjsw=1.05 cgdo=1.05
cgso=1.05)
..MODEL ss_wc_nch_xs nmos(tox=960m vth0=750m cj=950m cjsw=950m cgdo=950m
cgso=950m)
Kevin Aylward
[email protected]
hi Kevin,
thanks for the information. But I'm actually looking for something
slightly different.
Its my mistake, since I didnt mention it clearly or rather not mention
it at all.
I'm looking at on chip variations. So, modelling the entire design at
SS or FF is too pessimistic.
So, within the same chip, vt etc of the transistors are going to vary.
I can take this into account if I do a statistical modelling (both at
SS and FF).
So, I get the delays as a probability distribution.
So, for a given value of vt, transconductance etc, I run spice and get
the delay.
Now, I vary these parameters accroding to some probability and get
various delays with various probabilities.
This way I can take care of on chip variations probabilistically.
Now, the issue is getting into the exact details of the modelling.
Every parameter vt, cgdo, cgso, gm, idss, AS, AD etc will vary. The
idea is to take uncorrelated parameters
as much as possible. Also if I take too many parameters, its difficult
to model.
So I would like to take some 2 or 3 dominant guys. I'm thinking of vt
and transconductance.
Are these choices ok??
ganesh
W
Watson A.Name - \Watt Sun, the Dark Remover\
hi,
Try sci.engr.semiconductors
F
Frank Moe
take about 10% of the worst case variation as the relative variation
across the chip as long as the chip is reasonably siced.
Frank
K
Kevin Aylward
hi Kevin,
slightly different.
it at all.
It can be, but it it don't really matter if you can actually achieve a
design that meets spec anyway. You usually only need to try and fine
tune the calculation if the worst case design looks like the design wont
make it.
I personally use that fact that wc can give a pessimistic answer to give
me more confidence that the design will work for the conditions that are
either not checked, or the models themselves are not accurate enough.
SS and FF).
the delay.
My personal view is that this approach (MC) is not that wonderfull. The
reason being that, imo, one needs very large numbers of runs to account
for all conditions. Transient runs can take a long time.
to model.
That's why one often just does worst case. Its a compromise between
simulation time and accurate results.
I can tell you one thing though, in many companies, unless you do a wc
set of runs, you wont get a sign off from your manager to get masks
made.
What ever you do n addition, realistically, it *must* pass WC (not MC)
to go to fab. End of story.
I noted in the other post what *are* the dominant ones to consider, you
probaly missed this point being made, so I will repeat it:
These are the wc ratios (3 sigma) provided by a well known fab house.
cgso=1.05)
cgso=950m)
tox effectively varies the transconductance as the transconductance
parameter k=u.epsilon/tox
The above are the variations typically provided by fab houses. They
don't provide much data on the other parameters in the BSim3 models.
Kevin Aylward
[email protected]
