Modulator PAL B/G 6.5 MHZ sound spacing to B/G 5.5 or 6 Mhz s. spacing
I have a small broadcast CABLE tv system. Using 12 Modulators
which accept 12 Audio /Video signals and output composite RF signal.
Each RF output of each Modulator will then feed a signal mixer. So
there are 12 channels. The system is PAL B/G with 6.5 sound spacing.
The problem is that most of the users have only PAL B/G 6 mhz
Televisions. So the users can get the video picture but no sound OR
SOUND WITH TERRIBLE HUMMING
Question is how I can tune the modulator with 6.5 mhz of sound spacing
TO SOUND SPACING 5.5 OR 6 MHZ.
PETER
B
b
[email protected] ha escrito:
PETER
If you are talking about the audio carrier, Pal BG is 5.5mhz and Pal I
is 6mhz. There is no such thing as a ' Pal BG 6mhz
telvision'....perhaps you need to rephrase your question, as it doesn't
seem to make sense.
-B.
B,
tks for your reply.
Yes, The modulator is Pal B/G with 6.5 MHZ sound sub carrier. I need to
make it back to Pal B/G WITH 6 MHZ SOUND SUB CARRIER.
the modulators are ordered mistakenly with sound carrier 6.5 mhz apart
from the video signal.
I now need to tune it back to make it work in a country where the tv
are pal b/g 5.5 or 6 mhz sound carrier.
B
b
B,
tks for your reply.
.....6.0 ? 6.5? that's *not* pal B-G!!!
pal D is 6.5
pal I is 6.0
what you mean to say is that you're trying to adapt a pal- D device to
a pal-I.
Usually this involves changing a few coils.
-B.
