D
[email protected]
Hello folks,
Can I modify a Kidde smoke detector?
I'm wondering if someone out there can help with my dilema. I live
in a neighborhood where there have been 3 lightning strikes to houses,
causing attic fires, in the past 3 years. Two of those houses burned
completely and will be razed. The third fire was seen by kids in time
to warn the occupants who were in the house at the time and they saved
the house. I would like to extend my wired smoke alarm system to
protect the attic space.
However, I do NOT want a wired alarm in the attic, because I reason
that it increases the likelyhood that a lightning strike will destroy
the entire alarm system. I thought that Kidde WIRELESS smoke alarms
offered a perfect solution. I have a wireless unit in the attic,
another attached to my wired system, which sets the whole system off,
and a third on the main floor as a backup. If a strike destroys the
wired alarm system, I've still got the redundant wireless system
working.
Unfortunately, it gets too hot in the attic and the alarm is set off
by the heat. I do not believe dust is a problem in the attic - my
air conditioner stays cleaner than my desk. The problem seems to be
just the excessive heat. So, I am looking for a solution that still
allows me to use the wireless unit.
Is anyone out there familiar enough with Kidde wireless smoke
detectors to know if I can change a component on the PCB that alters
the temperature alarm point? I'm thinking there may be a
discrete component on the PCB to accomplish the temperature sensing,
rather than a sensor built into the chip. I have not taken the alarm
apart yet because the wireless unit is expensive, but from what I can
see, there ain't much in there. It's surface mount technology on a
small PCB. Might anyone have a schematic for these things? If it
seems a modification is possible, I'll go ahead and open the unit up
and give it a shot.
Any advice is thankfully accepted. I'd like to try to get some fix
up and running soon, as lightning season is upon us, and I'd like to
spend my time researching a proper lightning protection system. In
the meantime, I still would like to protect the attic space.
Thanks.
Dan
working.
and give it a shot.
Thanks.
Dan
