R
[email protected]
i have 5 windows to protect. Cant do it with regular beams. Basically
it is like this: Cant remember what you call that besides an arch (?)
It has 5 windows, one on each side. The window frames are very small. I
was just going to protect these with some Mini Wireless TX's from
Ademco, but the client really wants to keep the windows open alot, and
I was trying to get away from venting. There is nothing to put a beam
to cross all of them. Same type of set up in the back yard but the
house goes out more so I can cross those windows with a beam.
Are there any mini outdoor beams that I can put on the outside frame of
the windows? The gap on the window frame is small, like 1" maybe, there
is nowhere to mount a full beam, between the windows is just a couple
inches.
Or is there any small Motion I can mount inside the frame, looking
down? The window is a double hung, lower side only moves, goes up.
Screen is on the outside.
this is kinda what it looks like:
Also, are there any recessed mini Motions, that have pet imunity, or at
least can be mounted half way down the wall and the beam pattern only
looking straight ahead and/or up so as not to catch the cat. It is
brick wall with sheetrock over it (small space in between).
thanks
rory
inches.
thanks
rory
